How to Set Up Guest WiFi Network on RV340W?
devon12345678
I need help setting up a guest WiFi network on my RV340W. I would like guests to be able to access the internet but not our shared drives etc.
I was trying to follow these instructions: https://community.cisco.com/legacyfs/online/attachments/document/files/5054_-_configuring_a_guest_wireless_networkwap371rv130sg300_-_5044_5072.pdf but they are not applicable exactly to the RV340W. Maybe I need to get matching hardware? I have attached a diagram of my network setup.
I followed those instructions pretty closely. I have a VLAN set up with VLAN ID 25. I have LAN1,2,and 4 set to excluded and LAN3 set to tagged. My default VLAN ID is 1 and all 4 ports are set to untagged. I created a WiFi network and set its VLAN to 25. I can see the SSID and connect to it, but I don't get any internet.
6 Replies 6
 On the print you sent, on vlan 25 says DHCP disable. Are you getting IP address when connect on the SSID?
Yes. "The WiFi has the self-assigned IP Address 169.254.28.127 and will not be able to connect to the Internet"
However, I cannot find the device anywhere on the DHCP Bindings table.
169.254.x.x means no IP address. This is APIPA address.  You probably dont have DHCP running
I probably don't. What do you suggest I do? Should I use a Server type DHCP? Relay Type? What do I fill in for all those empty fields?vlan.PNGvlan server.PNG
Server.
devon12345678
That worked! Thank you.
