How to switch from telnet from ssh
h.escobar
I'm trying to switch over from telnet to ssh but the switch is at a remote location. I created a local user account, generated the rsa keys for ssh, and enable ssh version 2.  How do I change the current config to allow for ssh without locking my self out.
Below is the current config.
line con 0
password 7 jhdhdjhdkjdjdjdjd
login
line vty 0 4
login
line vty 5 15
login
Hello
Remotely log into the switch and save the running configuration then set a scheduled reload of the switch incase you've lock yourself out then change the vty lines to allow local username access and both telnet and ssh.
Then open an additional ssh session and once you've managed successful to access the device remotely via ssh you can change access just to accommodate ssh, cancel the schedule reload and save your configuration
wr
reload in xx
line vty 0 X
login local
transport input telnet ssh
after successful a ssh access
line vty 0 X
transport input ssh
reload cancel
wr
Kind Regards
Paul
h.escobar
Do I need to also do
aaa new-model
aaa authentication login default local
Hello
No you don't have too, the login local on the vty lines will use the switch local userbase for authentication, however is you want AAA you can do then by default you wouldn't require the login  local applied to the vty lines.
example:
username xxx secret xxxx
aaa new-model
aaa authentication login default local-case
aaa authentication enable default line  <  this will use you already vty line password
aaa authorization exec default if-authenticated
Kind Regards
Paul
