how to sync RTC with ntp after reboot - Cisco 3925
dahua.huang
We bought a used 3925 with SPE200 router from Ebay for lab training.  no smartnet, no support.
(our Data Center has full smartnet and support)
on board RTC battery run out and our team (IT geeks) replaced it.
My question is how to sync RTC clock with NTP or set it up. because it keep say
*Feb 6 06:30:22.048: %MAINBOARD-3-RTC_BATTERY_FAILURE: Real Time Clock (RTC) oscillator problem detected
and show clock was  Wed Feb 6 2036
after fully reboot, router will sync with NTP with correct time, but RTC wont snyc.
Please and any hidden/special cmd for sync RTC?
Thank ahead.
6 Replies 6
balaji.bandi
Battery gone bad, required replacement, since you brought from ebay, it may not have cisco support, so open the Kit, and get the same model of batter and replace.
configure Router local tme zone
configure NTP follow below document :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4000/8-2glx/configuration/guide/ntp.html
BB
dahua.huang
Thanks a lot.
We replaced battery with a CR2032 but still say failed during reboot.  we checked battery and all good /measured.
*Jan 2 00:00:01.602: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jan 2 00:00:01.790: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3900e Next reboot level = ipbasek9 and License = ipbasek9
*Jan 2 00:00:01.812: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3900e Next reboot level = securityk9 and License = securityk9
*Feb 6 07:23:45.026: %MAINBOARD-3-RTC_BATTERY_FAILURE: Real Time Clock (RTC) oscillator problem detected, possibly caused by RTC battery failure
# show env
REAL TIME CLOCK BATTERY STATUS
Battery Failed (checked at power up)
any thoughts?  Thanks ahead.
Can you post show version and show clock
BB
dahua.huang
Here we go with "show ver", "show clock" and "reload"
Thanks ahead.
lab_3925e#show ver
Cisco IOS Software, C3900e Software (C3900e-UNIVERSALK9-M), Version 15.6(3)M9, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Thu 17-Sep-20 06:37 by prod_rel_team
ROM: System Bootstrap, Version 15.1(1r)T4, RELEASE SOFTWARE (fc1)
lab_3925e uptime is 15 hours, 54 minutes
System returned to ROM by reload at 15:03:09 EDT Thu Jun 24 2021
System restarted at 15:05:47 EDT Thu Jun 24 2021
System image file is "flash0:c3900e-universalk9-mz.SPA.156-3.M9.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3925-CHASSIS (revision 1.0) with C3900-SPE200/K9 with 754688K/293888K bytes of memory.
Processor board ID FTX1613AHUX
4 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
256K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 C3900-SPE200/K9 FOC16075NBJ
Suite License Information for Module:'c3900e'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
datak9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information for Module:'c3900e'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
uc None None None
data None None None
lab_3925e# show clock
07:00:43.854 EDT Fri Jun 25 2021
lab_3925e#show run | inc ntp
ntp server 216.239.35.0
lab_3925e#
lab_3925e#reload
Proceed with reload? [confirm]
Jun 25 11:01:45.394: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
Copyright (c) 2011 by cisco Systems, Inc.
Total memory size = 1024 MB - DIMM0 = 512 MB, DIMM1 = 512 MB
CISCO3925-CHASSIS with C3900-SPE200/K9 with 1048576 Kbytes of main memory
Main memory is configured to 72/72(dimm 0/1) bit mode with ECC enabled
Readonly ROMMON initialized
Booting c3900e-universalk9-mz.SPA.156-3.M9.bin ...
IOS Image Load Test
___________________
Digitally Signed Release Software
program load complete, entry point: 0x100410, size: 0x717b8c4
Self decompressing the image : ################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################# [OK]
Smart Init is enabled
smart init is sizing iomem
TYPE MEMORY_REQ
OIR memory 0x00C00000
Onboard devices &
buffer pools 0x112CF858
TOTAL: 0x11ECF858
Rounded IOMEM up to: 287MB.
Using 28 percent iomem. [287MB/992MB]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Installed image archive
export@cisco.com.
Press RETURN to get started!
*Jan 2 00:00:01.814: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3900e Next reboot level = securityk9 and License = securityk9
*Feb 6 22:44:06.026: %MAINBOARD-3-RTC_BATTERY_FAILURE: Real Time Clock (RTC) oscillator problem detected, possibly caused by RTC battery failure
*Feb 6 22:44:19.884: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to down
*Feb 6 22:44:19.884: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
*Feb 6 22:44:19.884: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to down
*Feb 6 22:44:19.884: %LINK-3-UPDOWN: Interface GigabitEthernet0/3, changed state to down
*Feb 6 22:44:21.126: %PA-3-PA_INIT_FAILED: Performance Agent failed to initialize (Missing Data License) msi capabilities: 817005
*Feb 6 22:44:36.195: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Initialized
*Feb 6 22:44:36.197: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Enabled
*Feb 6 22:44:37.715: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
*Feb 6 22:44:37.715: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
*Feb 6 22:44:37.715: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
*Feb 6 22:44:37.715: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to down
*Feb 6 22:44:37.715: %LINEPROTO-5-UPDOWN: Line protocol on Interface Onboard VPN, changed state to up
*Feb 6 22:44:40.442: %SYS-6-CLOCKUPDATE: System clock has been updated from 22:44:40 UTC Wed Feb 6 2036 to 17:44:40 EST Wed Feb 6 2036, configured from console by vty0.
*Feb 6 22:44:40.442: %SYS-6-CLOCKUPDATE: System clock has been updated from 17:44:40 EST Wed Feb 6 2036 to 17:44:40 EST Wed Feb 6 2036, configured from console by vty0.
Feb 6 22:44:40.496: %SYS-5-CONFIG_I: Configured from memory by console
Feb 6 22:44:41.189: %SYS-5-RESTART: System restarted --
Feb 6 22:44:41.501: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
Feb 6 22:44:41.501: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
Feb 6 22:44:43.219: %SYS-6-BOOTTIME: Time taken to reboot after reload = 175 seconds
Feb 6 22:44:44.810: %LINK-5-CHANGED: Interface GigabitEthernet0/0, changed state to administratively down
Feb 6 22:44:44.810: %LINK-5-CHANGED: Interface GigabitEthernet0/2, changed state to administratively down
Feb 6 22:44:44.810: %LINK-5-CHANGED: Interface GigabitEthernet0/3, changed state to administratively down
Feb 6 22:44:46.810: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
Feb 6 22:44:59.136: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0/1 assigned DHCP address 10.1.1.92, mask 255.255.255.0, hostname lab_3925e
lab_3925e>show clock
17:45:17.659 EST Wed Feb 6 2036
lab_3925e>
Feb 6 22:45:41.416: %LICENSE-1-VALIDITY_ENDED: Feature datak9 1.0 has expired. UDI=C3900-SPE200/K9:FOC16075NBJ
Feb 6 22:45:41.416: %LICENSE-1-VALIDITY_ENDED: Feature uck9 1.0 has expired. UDI=C3900-SPE200/K9:FOC16075NBJ
07:05:51.016 EDT Fri Jun 25 2021
Not sure if the device detected new battery or replaced with right one, i leave on for some time so the batter charges and recover.
I do see time corrected after boot.
Looks like your license got expired,(other issue not part of the issue you posted here)
BB
dahua.huang
thanks for quick responds.
We measured board and shows 3V, we also tried flip over battery, but result same.
not sure how to correct RTC clock after battery changed.  need special/hidden cmd to sync with NTP???
the time corrected due to synced with NTP.
Thanks again
