01-12-2010 01:43 AM
I have installed and configured an evaluation copy of CiscoWorks LMS3.2 but now that I purshased a copy from Cisco, I need to upgrade the license. Cisco have not provided any details of license. Could someone please let me know the procedure to follow for upgrading from evaluation to full version.
01-12-2010 09:58 AM
Place the license file you got from Cisco (i.e. the .lic file) under NMSROOT. Then, go to Common Services > Server > Admin > Licensing, and click Update. Select this .lic file, and all applications should become licensed. No restart will be required.
01-12-2010 11:15 AM
Backing up one step from Joe's response, when you purchase a license, you should receive a Product Authorization Key (PAK).
Go www.cisco.com/go/license and register your PAK there. You will be sent the .lic file for installation via e-mail.
01-13-2010 05:54 AM
Many thanks for your replies. I didn't get the PAK with the DVDs but have now contacted Cisco to send it to me.
01-13-2010 09:17 AM
Please rate helpful posts and whether your question has been answered.
