05-17-2017 09:22 AM
I need to upgrade 2 cisco 4507 with redundant supervisor on VSS, I already check the standard procedure but I would like to know the steps to load the images to the 4 supervisors and restart the VSS array simultaneously, I hope they can help me.
05-18-2017 03:23 AM
05-18-2017 09:22 AM
This is the procedure that I intend to follow (Sorry about the Spanish)
Show runing-configuration
Show vlan
Show ip int brief
Show interface status
show ver | in IOS
show ver | in ROM
show license image levels
show switch virtual
show switch virtual role
show switch virtual link
show switch virtual link port-channel
delete bootflash: **********
copy tftp bootflash:
copy bootflash: slavebootflash:
sw1-slot5-bootdisk:
sw1-slot6-bootdisk:
sw2-slot5-bootdisk:
sw2-slot6-bootdisk:
verify /md5 bootdisk: *********
boot system flash bootdisk: **********
no boot system flash bootflash **********
show bootvar
show switch virtual
redundancy reload shelf
reload shelf
show switch virtual
redundancy force-switchover
But I do not know if it's the best option.
05-18-2017 02:06 PM
02-03-2021 06:56 AM
Do you know the process to reload each card one by one in SSO mode to have a minimal outage by switchover ?
Thank you.
02-03-2021 01:49 PM - edited 02-03-2021 01:49 PM
I would not recommend doing this because this is what gets done during ISSU or FSU/eFSU.
I, personally, do not use ISSU or FSU/eFSU in production network because it is usually does not work.
02-10-2021 07:13 AM
Thank you Leo.
