How to use Multimode SFP GLC SX MMD in Catalyst2960S and single mode OFC network , what fixes like mode conditioning cable is needed
SB123
We have single mode fiber optic network  between buildings and CAT 6 CAT  5 LAN inside each building of campus with Ethernet and gigabit Ethernet switches and ordered for "GE SFP MODULE " - LC CONNECTOR 'LX/LH" TRANSCEIVER FOR SINGLE MODE FIBER FOR  CISCO CATALYST but the supplier has delivered "GE GLC-SX -MMD ".Now what to do with this because the switch is not working with this transceiver or in other words 2960 S SWITCH does not recognize "GE GLC-SX -MMD " because indicator is not lighting up  What type of mode conditioning patch cable or other cost effective fix and all possible alternatives to make "GLC SX MMD" work with CATALYST 2960 S SWITCH and single mode fiber optical network .What will be the configuration.Please help and advice
0 Replies 0
