I am not able to see Firewall ASA 5585 links to our HP network node manger.
ASA is having multiple context (2 context) mode. having portchannel to two different NExus 7k (vpc).
ASA config is also attached here. NNM can discover ASA via management interface but does not show the data link between ASA and Nexus. I am not too sure if NNM is confused due to vpc or firewall multiple context ?
fw01/admin# sh running-config snmp-server
snmp-server host management 1.x.x.x community **** version 2c
snmp-server location Slv
snmp-server contact xyz@ad.com
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
snmp-server enable traps memory-threshold
snmp-server enable traps connection-limit-reached
snmp-server enable traps cpu threshold rising
