HSRP Failing with Vlan and Physical interface
DEENA SLOAN
We have Router1 and Router 2  interface's that are trunked to a switch and Vlan/Vlans that flow through the interface that is trunked.
When the physical interface on Router 1 fails it goes to standby but the vlan interface is staying active on router 1. The physical
interface on Router 2 becomes active, but the Vlan interface on Router 2 stays in standby. This causes the Vlan to become confused
in which way the data should flow. The only way to fix it is to physically shutdown the Vlan interface on Router 1 for Router 2 to become active.
We have tried the track interface command on the Vlan interface but it does not work. Any suggestions?
Here are the config for the physical interface and the Vlan interface.
Thanks Deena
Router 1
Physical interface:
interface GigabitEthernet2/4
description ***PRI S1110 A/L***
switchport trunk native vlan 1000
switchport mode trunk
Vlan interface:
interface Vlan380
description PRI_PRIVATE-WIRED_VAB
ip address 163.206.131.244 255.255.255.0
ip access-group 110 in
no ip redirects
no ip unreachables
ip pim dense-mode
ip cgmp
ip policy route-map open-island
standby 11 ip 163.206.131.254
standby 11 priority 115
standby 11 preempt
standby 11 authentication XXXX
standby 11 track GigabitEthernet2/4
Router 2
Physical interface:
description ***S1220 A/L***
Vlan interface:
interface Vlan380
ip address 163.206.131.245 255.255.255.0
no ip redirects
no ip unreachables
standby 11 preempt
standby 11 authentication XXXXX
duncanm
You have an issue there with your priority. You have standby 11 priority 115 on Router 1 while tracking interface G2/4. If you do not set an explicit decrement value, then the value is       decreased by 10 for each interface that goes down, and decrements are       cumulative. Since Router 2 is left at default (100) it cannot become active because it will always have a lower priority. You may want to set your priority on router 1 to something lower than 110, like 105.
