HSRP not working on subinterfaces
Rudy558
I'm new to networking and am trying to configure HSRP and router on a stick on two routers. I can't seem to get my configs to work. Sorry if this is a basic question, I'm definitely still learning.
Here's the topo:
I need HSRP for VLANs 10,20,30,40 between HQCore_1 and HQCore_2. HQCore_1 should be the primary for VLANs 10 & 30, and the secondary for VLANs 20 & 40. HQCore_2 should be the primary for VLANs 20 & 40, and the secondary for 30 & 40.
Here are the commands I've been using:
HQCore_1
Int g0/0
    No ip add
    Standby v 2
    No sh
    Exi
Int g0/0.10
    Encap dot1q 10
    Ip add 172.16.0.2 255.255.254.0
    Standby 10 ip 172.16.0.1
    Standby 10 priority 105
    Standby 10 preempt
    Exi
Int g0/0.20
    Encap dot1q 20
    Ip add 172.16.2.2 255.255.254.0
    Standby 20 ip 172.16.2.1
    Exi
Int g0/0.30
    Encap dot1q 30
    Ip add 172.16.4.2 255.255.255.128
    Standby 30 ip 172.16.4.1
    Standby 30 priority 105
    Standby 30 preempt
    Exi
Int g0/0.40
    Encap dot1q 40
    Ip add 172.16.4.130 255.255.255.192
    Standby 40 ip 172.16.4.129
    Exi
Int g0/0.88
    Encap dot1q 88 native
    Exi
HQCore_2
Int g0/0
    No ip add
    Standby v 2
    No sh
    Exi
Int g0/0.10
    Encap dot1q 10
    Ip add 172.16.0.3 255.255.254.0
    Exi
Int g0/0.20
    Encap dot1q 20
    Ip add 172.16.2.3 255.255.254.0
    Standby 20 priority 105
    Standby 20 preempt
    Exi
Int g0/0.30
    Encap dot1q 30
    Ip add 172.16.4.3 255.255.255.128
    Exi
Int g0/0.40
    Encap dot1q 40
    Ip add 172.16.4.131 255.255.255.192
    Standby 40 priority 105
    Standby 40 preempt
    Exi
Int g0/0.88
    Exi
The routers take the commands just fine, but when I do a show standby brief, I get this:
If I understand this correctly, the 'unknown' listed in the Standby column means it doesn't know where the backup is and therefore I've configured something incorrectly? I can't figure out what I'm doing wrong and would appreciate any guidance.
Thanks in advance!
Let me know if you need more info than the info provided here.
Richard Burts
The partial configs given by the original poster seem reasonable. The symptoms suggest that the Core routers are not communicating with each other. Perhaps a first step in investigating this would be the output of show cdp neighbor and see if the Core routers see the switches as a neighbor.
It would be helpful if we had some information about the switches that connect to the Core routers. What interface on the switch connects to the router? Is that switch interface configured as a trunk and does it carry vlans 10, 20, 30, and 40 as tagged vlans?
Rick
Rick
5 Replies 5
Seb Rupik
Hi there,
Can you confirm that HQCore1 is the STP root bridge for VLANs 10 & 30 and HQCore2 is the STP root bridge for VLANs 20 & 40.
The first step in troubleshooting this should be to check the STP state of the VLANs. Can you share the output of sh spanning-tree vlan 10 on switches: HQCore1, HQCore2, HQ_S1, HQ_S2, HQ_S3, HQ_S4 .
cheers,
Seb.
Thank you for the help! I'm sure you can see from the result of the post, it turns out I accidentally misconfigured the trunks on the switches.
Thank you for the update. Good to know that you have fixed the problem. Glad that my suggestions pointed you in the right direction. Thank you for marking this question as solved. This will help other participants in the community to recognize discussions that have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
Rick
Richard Burts
Rick
Rick
I did as you suggested and it appears the trunking on the switches were misconfigured. I really appreciate the guidance, it works now! Thanks!
