HTTP Event Detector
Levi Iiams
Is there a way to create an event detector that will basically listen for an http get or post?
I want to be able to stand up a tunnel interface when a POST is made directly to the router, for instance.
I've found some vague references, but nothing definitive on this.  If it turns out my google skills are all that need work here... my apologies!  Any help would be greatly appreciated!
Joe Clarke
No, there is no HTTP ED.  However, you can download the EEM HTTP server and use that as a way to detect your POST.
http://www.cisco.com/assets/cdc_content_elements/docs/ios/eas/easy-httx.tar
Joe Clarke
Oh my, thank you for this!!!  This also led me to your EASy installer.  Very cool stuff, thanks sir!
