HUM Interface utilization report error
Hi Joe,
     I have LMS 3.1 installed at one of our client site.
In HUM they are pulling the interface utilization repor
t for routers. we are observing the utilization valu
es comming in the reports are false. the values are in bytes/sec fomat. lets there is a link of 1 GbPS in one of my device. if i am converting the TX utilization in to Gbps it becames 4.04 Gbps. how it is possible that the tx load will reach to 4 Gbps on a 1 Gb link?
Please help me.
Satya
Joe Clarke
Exactly what version of HUM are you using?
Hi Joe, It is HUM 1.1
HI Joe,
     It is exactly HUM 1.1.0 . please help me to resolve this problem.
You need to upgrade to 1.1.2 to get 64-bit support which is required for such high-speed interfaces.  This can be downloaded at http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-hum .
