I am having and SSH issue in EVE-NG on cisco Version 15.9(3)M6 router
w1993834
I have been trying to establish an SSH connection from my EVE-NG Ubuntu station to an image of a Cisco Version 15.9(3)M6 router and I keep getting the error "no matching key exchange method found. Their offer: diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1" on my Ubuntu machine.
Mind you I have already adjusted ssh_config file on my Ubuntu work station with:
"Host 192.168.0.100
  KexAlgorithms +diffie-hellman-group-exchange-sha1, diffie-hellman-group14-sha1"
Also SSH works fine in EVE with my layer 3 Cisco switch image I have. I simply need to add the above text to the ssh_config file on my Ubuntu station (adjusting host IP accordingly). I have used the same ssh configs on both the switch and router.
"hostname device
ip domain name cisco.com
username admin priv 15 password admin
crypto key generate rsa modulus 2048
line vty 0 15
transport input ssh
login local"
 show ip ssh output on router:
"SSH Enabled - version 1.99
Authentication methods:publickey,keyboard-interactive,password
Authentication Publickey Algorithms:x509v3-ssh-rsa,ssh-rsa
Hostkey Algorithms:x509v3-ssh-rsa,ssh-rsa
Encryption Algorithms:aes128-ctr,aes192-ctr,aes256-ctr
MAC Algorithms:hmac-sha2-256,hmac-sha2-512,hmac-sha1,hmac-sha1-96
KEX Algorithms:diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1
Authentication timeout: 120 secs; Authentication retries: 3
Minimum expected Diffie Hellman key size : 2048 bits"
I have tried adjusting the modulus bits from 1024-4096 but still no luck.
Has anyone experienced a similar issue in EVE-NG? Any further suggestion I could try? I am happy to provide more configs if it would help.
@w1993834 as per the error message your SSH client not support proposed KEX by router. try enabling required KEX in your SSH client. alternatively use Putty  with enabling all supported KEX.
Good luck
KB
Jsapkom
looks lie you have only adjusted to host 192.168.0.100 only. Just need to put * for all the hosts
Ignore the above as i See you had this done. The ssh_configs need to be adjusted in the ubuntu which is acting as client to the ssh.server. No need to adjust it to the server. Enable ip-ssh version 2
kexAlgorithms +diffie-hellman-group14-sha1
ciphers +aes128-cbc
PublickeyAcceptedAlgorithms +ssh-rsa
HostKeyAlgorithms  +ssh-rsa
Dear sir,
May you explain this in plain English.
Thanks in advance
Bipa
