I can not connect ssh in cisco asa 5515-x
Hamid Amir
Dear all
I cannot access ssh after replacing my broking cisco asa 5505 with cisco asa 5515-X, although I can access ASDM .
Can you help Please ?
ciscoasa# sh run int
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address dhcp setroute
interface GigabitEthernet0/1
bridge-group 1
nameif inside_1
security-level 100
interface GigabitEthernet0/2
bridge-group 1
nameif inside_2
security-level 100
interface GigabitEthernet0/3
bridge-group 1
nameif inside_3
security-level 100
interface GigabitEthernet0/4
bridge-group 1
nameif inside_4
security-level 100
interface GigabitEthernet0/5
bridge-group 1
nameif inside_5
security-level 100
interface Management0/0
management-only
nameif management
security-level 100
ip address 10.0.0.1 255.255.255.0
interface BVI1
nameif inside
security-level 100
ciscoasa# sh run ssh
ssh stricthostkeycheck
ssh 192.168.1.0 255.255.255.0 outside
ssh 192.168.1.0 255.255.255.0 inside
ssh timeout 5
ssh version 2
ssh key-exchange group dh-group1-sha1
ciscoasa# sh run aaa
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
aaa authentication login-history
ciscoasa# sh run http
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.1.0 255.255.255.0 inside_1
http 192.168.1.0 255.255.255.0 inside_2
http 192.168.1.0 255.255.255.0 inside_3
http 192.168.1.0 255.255.255.0 inside_4
http 192.168.1.0 255.255.255.0 inside_5
http 0.0.0.0 0.0.0.0 inside
38 Replies 38
Hi Marce
Still same problem with both configuration below.
ciscoasa(config)# no ssh 0.0.0.0 0.0.0.0 inside
ciscoasa(config)# no ssh 0.0.0.0 0.0.0.0 outside
ciscoasa(config)# ssh 192.168.1.0 255.255.255.0 outside
ERROR: entry for address/mask = 192.168.1.0/255.255.255.0 exists
ciscoasa(config)# ssh 192.168.1.0 255.255.255.0 inside
WARNING: SSH on BVI works over VPN tunnel only when management-access is enabled on this interface
ciscoasa(config)# man
ciscoasa(config)# no ssh 192.168.1.0 255.255.255.0 outside
ciscoasa(config)# no ssh 192.168.1.0 255.255.255.0 inside
ciscoasa(config)# no management-access inside
ciscoasa(config)# management-access inside
the DH group configured is the lowest one available. Try and change it to:
ssh key-exchange group dh-group14-sha1.
 - Adding to other reply , I would advise to take the following path to tackle this problem more fundamentally if problems persist : 1) Save the current configuration to an external device/directory (this probably isn't even needed because I assume that you have the configuration that you want to propagate to this device still around somewhere). 2) Erase the configuration on this ASA (write erase) 3) Reboot and start with a basic setup of the network (interfaces) 3) Then configure 'base SSH' as per Cisco documentation 4) If that works then gradually restore configuration parts from the original ASA and or merge them into the new ASA configuration. Any subsequent blocking of SSH-access will then also point out where the problem is.
 M.
Hi Marce
Same problem and errors even with clean basic configuration.
May be need open port forward?
I did open port 22, but still same problem.
Hamid
what client are you suing for the SSH connection, what syntax do you use to connect ?
Hi George.
I use PuTTYy in windows 10 with either  public  Ip address or local ip address 192.168.1.1, and I use WebSSH in my iphone. Every thing was Ok with Cisco asa 5505.
I have only problem with the replacement  cisco asa 5515-X.
Hamid
the 5505 is an ancient device, so I have a feeling this has something to do with more advanced security settings on the newer 5515-X.
When you enable debugging:
ASA5515X#debug ssh
Do you see any incoming connections at all ?
Hi George,
When I try to connect from  the computer connected to cisco I get this message using ASDM
22  TCP access denied by ACL from 192.168.1.5/59578 to inside_1:192.168.1.1/22.
When I use public ip address, no message at all.
Kind Regards
Hamid
I still think that it has to do with the ssh defaults. I have looked around in other posts, try and configure the ciphers below:
ssl cipher default custom "AES256-SHA256:AES256-SHA:AES128-SHA"
ssl cipher tlsv1 custom "AES256-SHA:AES128-SHA:DES-CBC3-SHA"
ssl cipher tlsv1.1 custom "AES256-SHA:AES128-SHA:DES-CBC3-SHA"
ssl cipher tlsv1.2 custom "AES256-SHA256:AES256-SHA:AES128-SHA"
ssl cipher dtlsv1 custom "AES256-SHA:AES128-SHA:DES-CBC3-SHA"
Still same Problem.
Kind Regards
Hamid
Does the debug output change when you configure these cypher keys ?
Hi George
I get same error, still Does not work.
Kind Regards
Hamid
try and configure an even lower modulus:
domain-name cisco
crypto key generate rsa label cisco modulus 1024
Hi George.
I tried both lower and higher value, but did not solved the problem.
ciscoasa(config)# domain-name cisco
ciscoasa(config)# crypto key generate rsa label cisco modulus 1024
INFO: The name for the keys will be: cisco
Keypair generation process begin. Please wait...
ciscoasa(config)# exit
Hamid
Hi Gorge,
The command  sh crypto key mypubkey rsa gave me list of few Keys, I deleted all of them by using  (crypto key zeroize rsa label) and generated  crypto key generate rsa  modulus 1024 with ssh 0.0.0.0 0.0.0.0 outside and ssh 192.168.1.0 255.255.255.0 inside, The problem has been resolved.
Thank you all  very much for great help.
Kind Regards
Hamid
