I can not login to CW LMS
yoguz
Hi there,
I have two identical CiscoWorks 2000 servers with the following components installed:
- CW Common Services SP3 2.2
- Monitoring Center for Performance 2.0.2
- IPS Management Center 2.1
- Resource Manager Essentials 3.5
- Resource Manager Essentials Incremental Device Support 3.5
- Security Monitor 2.1
At the begining there was no problem to login to these two servers, but now I can't login to one of the servers. The client browser loads the homepage, when I tried to login username and password everything stops. Then I checked the difference between two servers CW homepages, I found that, cookies are disabled in the server that I can't login. How can I start it on the server side?
Is there any idea about the situation?
yasemin.
15 Replies 15
Please provide your service startup parameters (multiple screenshots of the services control panel will work).
