IE-200-16TC-L AND CISCO NETWORK ASSISTANT SOFTWARE
J Rubio
Hello, for a project in the USA we provided several Ethernet Switches IE-200-16TC-L, the customer is asking about the Cisco Network Assistant Software for switch configuration, I searched in Cisco Website for such software and it seems to be discontinued, what software could we offer to our customer in Lieu of CNA?
6 Replies 6
marce1000
  - I can't find support for this device in Cisco Prime, advise the user to configure it manually ,
 M.
pieterh
I guess IE-200-16TC-L, is a typo? and should be IE-2000-16TC-L?
1) in the retirement notice: Cisco Network Assistant - Retirement Notification - Cisco
    Cisco refers to : You can view a listing of available Cloud and Systems Management offerings that best meet your specific needs
-> you should consider cisco Prime ad/or Cisco DNA  only if you have a large number of devices,
     else these products are too heavy!
-> for a limited number of devices you can use the web-management interface as first alternative
    "enter the switch IP address in a web browser to display the Device Manager"
     (and of course the CLI)
Yes, it was a typo, it should be IE-2000-16TC-L
We have only 5 units on-site. I found an option to upgrade the IE-2000 switch from Lite to Full (Part # L-IE2000-L-B=), would this help in anyway?
pieterh
>>> would this help in anyway? <<<
-> no this only gives you more features, not more management options
Cisco Industrial Ethernet 2000 Series Switches Data Sheet   table-5
p.s. if by chance this switch is used in a Profinet network, you can select a Profinet management tool
The application uses Modbus TCP/IP. Then what software license do you recommend us to purchase that could be equivalent to Cisco Network Assistant Software? I just want to mention that have near zero knowledge of ethernet switches, I am looking for a part number that can be ordered to meet the customer specifications in regards providing Network Assistant Software.
