Cisco FMC Setting up direct access SSH
rtarson
So I am trying to set up a simple connection from a trusted external IP to internal server. I currently have a NAT rule on both of our Firepowers. From what I can tell the NAT rules are working fine because when attempting to connect I do see my connections coming in they just keep getting blocked and I can not find out why. I did a packet trace and it is telling me that it is blocked by default rule. Which tells me that the rule did not match however I believe I set up the rules correctly for Out to in. I would appreciate any guidance as i am new to Cisco FMC/firepowers.
These are bogus ip for security reasons but just to give a picture of the setup
External IP NAT'd for the SSH Server Firepower (North Location): 180.168.104.15
External IP NAT'd for the SSH Server Firepower (South Location): 180.168.105.15
Internal IP of SSH Server: 10.0.0.168
So in the Access Control policy of Firepower(North and South):
  • Zones
    • WAN
    • Inside-Global-Zone
  • Networks
    • Source: Outside Vendor IPs (Containing a group of Host IPs)
    • Destination: Internal Host IP: 10.0.0.168
  • Ports for testing right now I have set Any for both source and dest
  • Action: Allow
I also added in the reverse order Inside to outside policy as well to allow any ports to that ip from that internal address. Of course only for testing purposes eventually will lock down to needed ports.
However it always seems to block the incoming connection.
Phase: 1
Type: INPUT-ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
Additional Information:
Found next-hop 00.00.00.00 using egress ifc  Inside(vrfid:0)
Phase: 2
Type: ECMP load balancing
Subtype:
Result: ALLOW
Config:
ECMP load balancing
Found next-hop 00.00.00.00 using egress ifc  WAN(vrfid:0)
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group CSM_FW_ACL_ global
access-list CSM_FW_ACL_ advanced permit ip ifc WAN any ifc Inside any rule-id 268435118
access-list CSM_FW_ACL_ remark rule-id 268435118: ACCESS POLICY: AccessPolicy - Mandatory
access-list CSM_FW_ACL_ remark rule-id 268435118: L7 RULE: GeoBlock-Inbound
 This packet will be sent to snort for additional processing where a verdict will be reached
Phase: 4
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
class-map class-default
 match any
policy-map global_policy
 class class-default
  set connection advanced-options UM_STATIC_TCP_MAP
service-policy global_policy global
Phase: 5
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 8
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
nat (Inside,WAN) source static SSHServer SSHServer_ExternalNAT
Result:
input-interface: WAN(vrfid:0)
input-status: up
input-line-status: up
output-interface: Inside(vrfid:0)
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule, Drop-location: frame 0x00005626461aa854 flow (NA)/NA
I'm a majooooor dum dum, I didnt deploy uuuugggghhhhh.
7 Replies 7
You have static NAT for SSH'
So only SSH to the mapped IP not to real IP.
Please SSH to mapped IP and share packet-tracer of this process here
This is with the destination set to the Static NAT:
Phase: 1
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
nat (Inside,WAN) source static SSHServer SSHServer_ExternalNAt
NAT divert to egress interface Inside(vrfid:0)
Untranslate 176.xx.xx.xx/22 to 10.0.0.183/22
Phase: 2
Subtype:
Result: ALLOW
Config:
ECMP load balancing
Found next-hop 176.xx.xx.73 using egress ifc  WAN(vrfid:0)
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 4
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
 match any
 class class-default
Phase: 5
Type: NAT
Subtype:
Result: ALLOW
Config:
Static translate 74.106.xx.14/22 to 74.106.xx.14/22
Phase: 6
Type: NAT
Result: ALLOW
Config:
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: VPN
Result: ALLOW
Config:
Phase: 9
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 10
Type: NAT
Result: ALLOW
Config:
Phase: 11
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 12
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 3816579539, packet dispatched to next module
Phase: 13
Type: EXTERNAL-INSPECT
Subtype:
Result: ALLOW
Config:
Application: 'SNORT Inspect'
Phase: 14
Type: SNORT
Subtype:
Result: DROP
Config:
Snort Trace:
MidRecovery data queried. Got session type 2 rule id: 268435116, rule_action:2, rev id:797914468, ruleMatch flag:0x5
MidRecovery data queried. Got session type 2 rule id: 268435115, rule_action:2, rev id:797914468, ruleMatch flag:0x5
MidRecovery data queried. Got session typSnort Verdict: (black-list) black list this flow
Result:
input-status: up
output-status: up
Action: drop
Drop-reason: (firewall) Blocked or blacklisted by the firewall preprocessor, Drop-location: frame 0x0000562647048602 flow (NA)/NA
It clear NOW
the snort drop ssh' instead of allow can checge the action to fastpath.
Thank you for the tip, what does that mean for me lol? Sorry I'm new to Cisco FWs just trying to piece it together lol.
Also is my Access Control Policy correct or should the destination be set to the Static NAT of the server?
First you are welcome'
And we all one day be some dum'
Welcome to party lol
Have a nice day friend.
MHM
