09-08-2022 11:47 PM
in case of LACP Should we match duplex/speed/bandwdith/vendors/vlan id on other side
09-08-2022 11:55 PM
To build LAG / PO below requirement high level :
1. all the ports should be same speed.
2. you can not mix 100 and 1GB or 10GB interfaces.
3. both sides should support LACP (in most case all vendors supports)
you can find more details on the vendor document if any - for example cisco :
09-08-2022 11:59 PM
It is not just "LACP", but etherchannel as a whole -- Speed has to match at both ends.
09-09-2022 01:23 AM
duplex/speed must match with or without LACP
vendors no need to match but vendor must support same protocol and same ver. (protocol meaning LACP or PAgP)
vlan id if port-channel is access and the SW is totally isolate then you can use different VLAN-ID in each SW,
vlan id if port-channel is trunk then the vlan id especially native VLAN must match
BW is match in one SW for all port member of port channel but it can different I think between two SW, BUT I sure you will face issue with traffic since the high BW send traffic much more than lower BW can handle.
09-09-2022 09:52 AM
"duplex/speed/bandwdith" need to match, yes.
"vendors" need to match, no.
"vlan id" need to match, that might not be required, but it's likely a misconfiguration if they don't match.
