In need of help on Netflow configuration on the new ISR4000
mmasenya
Hi there
My company has bought ISR4451 router as a replacement of ISR3800. It was easy and simple to configure netflow on the old routers like;
ip flow-export source Loopback0
ip flow-export version 5
ip flow-export destination 10.19.14.22 9996
This was enough to get netflow running our routers
I need some help or tips in getting netflow configured on the new ISR4000. I searched on the web and this is what i configured on my router but struggle to succeed,
flow record NTA
description NETFLOW
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input snmp
match interface output snmp
collect transport tcp flags
collect interface input
collect counter bytes long
collect counter packets long
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow exporter NTA
description Exporter for NTA
destination 192.168.3.2
source GigabitEthernet0/0/1.2211
transport udp 2055
export-protocol netflow-v5
template data timeout 60
flow monitor NTA
exporter NTA
cache timeout active 60
record NTA
on the interfaces i have the following;
interface GigabitEthernet0/0/0
description LINK-TO-LAN
ip address 172.18.255.42 255.255.255.252
ip flow monitor NTA input
ip flow monitor NTA output
interface GigabitEthernet0/0/1
no ip address
negotiation auto
interface GigabitEthernet0/0/1.2211
description LINK-TO-WAN
bandwidth 102400
encapsulation dot1Q 2211
ip address 172.16.0.10 255.255.255.252
Looking at the configs above, what have i missed to get netflow going?
Matthews
Mark Malone
hi heres a working one off my 4000s , your looks right
check this command see if the flows are trying to be sent first
xxxxxxxx#sh flow exporter statistics
Flow Exporter NetQos:
  Packet send statistics (last cleared 41w2d ago):
    Successfully sent:         58740008              (72672722641 bytes)
    No destination address:    24
flow record FLOW-RECORD
 description record to monitor network traffic
 match ipv4 tos
 match ipv4 protocol
 collect routing source as
 collect routing destination as
 collect routing next-hop address ipv4
flow exporter NetQos
 description export Netflow traffic to HQ
 destination x.x.x.x
 source Loopback3
 template data timeout 300
 option interface-table timeout 1000
 option exporter-stats timeout 1000
flow monitor xilinx_nq
 description Used for ipv4 traffic analysis (Mapped To FLOW-RECORD)
 record FLOW-RECORD
 exporter NetQos
 statistics packet protocol
Then under any layer 3 interface you want to collect add these
ip flow monitor xilinx_nq input
ip flow monitor xilinx_nq output
Hello Matthews,
You might want to consider exporting flow direction as well just in case you decide to export egress flows:
 match flow direction
Also, you can enrich your flow export by looking at this flexible netflow configuration. It includes NBAR, MAC address, VLANS, etc.
I hope this helps.
Mike
