Inexpensive bandwidth charts for ASA 5500
jimmyc_2
We need to collect some BW usage charts for our ASA interfaces.
We don't have the expensive Network monitoring software, and we are a very small shop.
I only need BW and data-drop graphs.
Any suggestions?
You can run it on Windows but it'll put you in a small minority. Instructions are here:
http://www.cacti.net/downloads/docs/html/install_windows.html
Most of the open source community runs on Linux. You can run it on an old laptop and just build a partition and install Linux (or load a hypervisor like Virtualbox and run Linux on that under Windows). The resource requirements for Linux and cacti are quite modest.
Marvin Rhoads
Cacti is open source and can query an ASA via SNMP to generate interface utilization and other graphs.
It takes a bit more work to setup than some of the commercial products but the acquisition cost is free.
There is some good community-contributed documentaiton on the cacti.net site. For example, installation is covered step-by-step here:
http://www.cacti.net/downloads/docs/contrib/Cacti-Linux-How-To.pdf
Looks like Cacti requires a WebServer.   Is it possible to run this just on a Windows Laptop?
