inlet temperature issue
CATYO
Level 3
Level 3
Hi there.
I have 6513s and  there is weird situation.
when i checked temperature "show env temperature" it shows intlet temperature is higher more than outlet temperature.
sho env tem
  VTT 1 outlet temperature: 28C
  VTT 2 outlet temperature: 32C
  VTT 3 outlet temperature: 29C
  module 1 outlet temperature: 40C
  module 1 inlet temperature: 50C
  module 1 asic-1 temperature: 55C
  module 1 asic-2 temperature: 58C
  module 1 EARL outlet temperature: 45C
  module 1 EARL inlet temperature: 35C
  module 2 outlet temperature: 39C
  module 2 inlet temperature: 50C
  module 2 asic-1 temperature: 51C
  module 2 asic-2 temperature: 58C
  module 2 EARL outlet temperature: 46C
  module 2 EARL inlet temperature: 37C
  module 3 outlet temperature: 39C
  module 3 inlet temperature: 50C
  module 3 asic-1 temperature: 51C
  module 3 asic-2 temperature: 56C
  module 3 EARL outlet temperature: 45C
  module 3 EARL inlet temperature: 36C
  module 4 outlet temperature: 38C
  module 4 inlet temperature: 48C
  module 4 asic-1 temperature: 49C
  module 4 asic-2 temperature: 54C
  module 4 EARL outlet temperature: 45C
  module 4 EARL inlet temperature: 36C
  module 5 outlet temperature: 38C
  module 5 inlet temperature: 49C
  module 5 asic-1 temperature: 49C
  module 5 asic-2 temperature: 55C
  module 5 EARL outlet temperature: 45C
  module 5 EARL inlet temperature: 37C
  module 6 outlet temperature: 38C
  module 6 inlet temperature: 47C
  module 6 asic-1 temperature: 47C
  module 6 asic-2 temperature: 52C
  module 6 EARL outlet temperature: 44C
  module 6 EARL inlet temperature: 36C
what seems to be the problem? I need your help
Thank you in advance.
Vinod Arya
It may be one of these. You may ignore, if you dont see any alert/alarms for high temperature :
CSCsi06813    WS-X6724-SFP/DFC3B may report EARL inlet temperature higher than outlet
CSCsi06811    WS-X6724-SFP/CFC may report inlet temperature higher than outlet
-Thanks
Vinod
**Rating Encourages contributors, and its really free. **
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Vinod Arya
-Thanks
Vinod
Thank you
but It's not WS-X6724.  actually it is WS-X6816-10GE
I can't find out in bug search that module.
but i may assume that it is possible to occure that module.
I checked further and it seems this LC is affected with another such issue with :
CSCuj78044    6716-10G (Hw ver 2.0) may report inlet temperature higher than outlet
Here both, both type ( 6716,6816) will see the issue. Fix for this bug is committed for 15.1(2)SY2 release ETA during Mar/Apr 2014.
-Thanks
Vinod
