Installing CiscoWorks 3.2
dryden333
I am installing CiscoWorks 3.2 on a Windows 2003 server. I am getting the following error "Cannot create the install dependency file."
Any assistance would be useful.
Thanks...
Shaun
5 Replies 5
Marvin Rhoads
Have you confirmed you meet the prerequisite requirements? (Link)
I do recall it is quite particular about you using the US-English or Japanese locale for the OS.
Unfortunately you won't be able to get any official TAC support since the product was last sold over 3 years ago and is part End of Support. (EoX notice)
I assume there's some reason you're trying to install that instead of the more current and much better LMS 4.2.
I am aware of the newer version and end of support. However, this is what I inherited. The server needed a fresh image, so I am just trying to get this system back up running in good order until I am able to get new hardware and software approved for purchase and ordered.
I do not beleive that is the issue. My OS in US-Engish and I have selected the same for CiscoWorks install wizard.
Thanks...
Some of the most basic check points before you begin install is :
> Log in as local administrator account. In any case it is not possible, login as a local account and not a domain admin account.
> Disable any 3rd party application, specially any Anti-Virus for the time being it is installed.
> Disable Windows Data Execution Protection (DEP)
> Set the per-user and global TEMP and TMP environment variables to short values (e.g. C:\WINDOWS\TEMP)
You should also check the media for its checksum if it is not corrupted. Share install log from c:/ to check further.
You can check other pre-reqs as best practices on windows install from here.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Thanks... Windows Data Execution Protection (DEP) and the Environment Variables were the problem. Thanks again. Shaun
Glad that it worked. You can resolve this thread and close if it has.
-Thanks
Vinod
**Encourage Contributors. RATE Them.**
