interface errors
aamit
Community Member
Is there an script that can monitor interface errors (input and output errors) and send an email out when it reaches threshold?
Joe Clarke
Sure.  Here's an example:
event manager applet error_monitor_GigabitEthernet0/1
event interface name GigabitEthernet0/1 parameter input_errors entry-op ge entry-val 5 entry-type increment poll-interval 10
action 2.0 cli command "enable"
action 3.0 cli command "show int GigabitEthernet0/1 | inc error"
action 4.0 mail server 10.1.1.1 from [email protected] to [email protected] subject "Errors on interface GigabitEthernet0/1" body "
Interface GigabitEthernet0/1 has seen $_interface_delta_value input errors in the past 10 seconds: $_cli_result"
Hi Joe,
Will the aforementioned script work on NX-OS ?
Thanks!
   -Alex
No, this won't work on NX-OS.  NX-OS doesn't have the email action, nor does it have the interface event detector.
