Interface name instead of ip address
gwatkinsqt
I'm running PrimeLMS 4.2.4.  I'm wanting to setup reverse telnet on several remote routers, so I'd like to use a NetConfig job to push out the configs.
I'm setting up a hostname on the routers to telnet through the aux port using the loopback0 address on the router.  So, if my Loopback address is 192.168.1.1 then the hostname line would look like "ip host revtel 2001 192.168.1.1"  Of course there is also some aux port config too.  I have that part complete.
Is there a way to push out the line "ip host revtel 2001 <ip address of Loopback0> with a NetConfig job?
AFROJ AHMAD
Hi ,
Are you able to push this config  ( "ip host revtel 2001 ) via CLI on the device ?
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
