Interface UPTIME in router
ramdas_2k
Dear All,
Hi, I got a small query.
Do we have any command that will show us the total uptime of a particular interface in routers.
If anyone know let me know....
Rgds
Ramdas
umedryk
Level 5
Level 5
You can find out the total up time of a router, but I think you cannot find out the up time of one particular interface on a router.
dave.keith
There are some SNMP MIB II variables that can be used to calculate the uptime.
ifOperStatus will tell you if an interface is up.
ifLastChange will tell you the value of SysUpTime when the interface went into it's current OperStatus.
SysUpTime - ifLastChange = time since an interface went up (or down, which is how I find switch ports that have not been used for some time).
Dave
