Internetwork Performance Monitor
CLIFFORD BECKER
I have created an HTTP Operation with a url http://www.website.com:8001/11nca everything else is set at the defaults. When I try to add a collector from one of my routers I get the error:
AddCollErr
REASON: Invalid Value Specified
I have also tried the IP address with the same error. The router is a 2621XM and I can setup collectors for Echo and PathEcho and DNS just fine. it is just HTTP any ideas?
steve.busby
Level 5
Level 5
Does the "website" have any requirement for USERID/Password? Remember the probe retrieves the base HTML page only.
I thought about that after I posted and changed the website to another server that is just text with no authentication an just uses port 80 with the same results. FTP works as well.
viswanathan123
hai,
I am also experiencing the same problem with little difference.
How to monitor the traffic? After i gave like this http://www.cisco.com:80 what form will be the Htt[p traffic shall i have launch monitore or statistical how long this should be running i am running this for one week but i find no graphs why? what may be the reason can u able to give some clue?
Viswanathan.M
Network Engineer
Tata Infotech Ltd.
kdamisch
Was there ever a resolution to this? I am using Common Services 3.0.4 and IPM 2.6 and have run into the exact same issue. The only collector I have a problem with is HTTP. I have a 2821 router and a 4506 switch configured as sources. The 2821 works just fine, but when I try to use the 4506 as the source for an HTTP collector (using the same operation as the 2821), I get a window that pops up labeled "IPM: Error Dialog Box"
AddCollErrTEST123
Kevin
