InterVlan and ROAS
joe97
hi, just try to understand inter-vlan and roas here.. but i have no idea what's wrong with my configuration here, the computer each vlan can't ping to other vlan. please help check the attachment and if possible, how to i know the miss or wrong configuration?
thank you
2 Accepted Solutions
M02@rt37
Hello @joe97
ROAS is good!
But you have to adjus SW_CORE trunk itnerfaces config!
Gig 1/1 to 5/1 should be in mode trunk! not mode access !
So on the switches on the other side, ensure that is a trunk port as well ! Allowed only the vlan id you need to propagate on Trunks !
Best regards
Martin L
any issues with inter-vlan and roas, make sure trunk is up and is allowing vlans. also make sure u have vlan x on all switches that need it - even transit ones.
5 Replies 5
M02@rt37
Hello @joe97
ROAS is good!
Best regards
Martin L
joe97
thank you @Martin L and M02@rt37 i'll try to fix the configuration and try again
Great !
You're so welcome.
Best regards
it's working, all pc0 can ping to other vlan
