Inventory Challenges
brooks-el
Hey guys,
I have another issue, and it has to do with Inventory Collection.
I have 3 1200 series AP's on my network, i have setup logging, snmp and telnet to function..i can collect configs from LMS, i can do an SNMP walk from LMS, but i can not do an inventory collection...it keeps telling me "Device sensed, but connection failed"
I can do a device credentials report and it shows telnet, snmp (ro and rw) passing, but no inventory....any idea's?
5 Replies 5
Joe Clarke
This is probably a device bug. Check the IC_Server.log for relevant errors.
David Stanford
Can you get the sysObjectID reported by the AP's? Also, what version of code are they running?
If you do the following does it make a difference:
Go to RME -> Admin -> System Preferences -> RME Device Attributes
Increase the snmp timeout to 60 seconds
Go to RME->DeviceManagement->Normal Devices-Choose the problem AP's and see if the results change
AP Version is 12.2(8)JA2
As I said earlier, look at the IC_Server.log for relevant errors. It will eliminate a lot of the guess work here.
