inventory collection fails on LMS4.0 with ASA5510
meijerivo
We have added the ASA5510 and 5505 manually to LMS4.0.
After doing an inventory discovery the result is it fails...so we can't continue doing anything with it in LMS.
Has anybody of you been able to add the ASA to LMS4.0??
If yes any advise you can give me?
I suppose it shoulf not be any different from LMS3.2
I used another test ASA with a blank config with an IP-address on the inside interface, nameif command and a snmp-server community ro string.
snmp-server enable is also there. ASA is running 8.2
LMS can ping the device and we can SSH to it (also enabled)
PLEASE help me....
Ivo
Netherlands
alplasmartnet
We have got the same problem!
A solution is needed too for our problem!
best regards
Matthias
