IOS compatibily with ISE
odusotewale
I am thinking of upgrading  my router and switches with the following IOS version and will like to know if they are interoperable with ISE because ISE is currently implemented in my networks.
IOS versions:
7.0(3)|4(7)
15.2.6E
3.6.7E
15.2.6E
03.16.6S
marce1000
  And the ISE version currently being used is .... ? Anyway start you research from below
    https://www.cisco.com/c/en/us/support/security/identity-services-engine/products-device-support-tables-list.html
M.
Sorry I forgot to mention that. The ISE version is version 2 patch 1. And thanks for the link.
