IOS packet capture on Cisco 2960 switches
Paul Morgan
Hi all,
Im trying to figure out if Im being dumb.
Im using various 2960 switches throughout the enterprise.
I can enter the commands for IOS packet captures in the same way as on my routers. But I never get any output. Im assuming this is because the switches are not enabled for CEF.
Is there any other way to get packet captures on these switches?
Commands used:
monitor capture buffer NAME circular
monitor capture point ip cef NAME all both
monitor capture point associate NAME NAME
monitor capture point start NAME
All help is appreciated before I set my switch cabinet on fire in despair.
Paul
rvarelac
Level 7
Level 7
Hi Paul ,
Unfortunately the switches cannot use Embed packet captures as the Routers. Instead you can use a SPAN session to capture the traffic.Check an example below:
https://supportforums.cisco.com/document/13891/how-configure-port-monitoring-span-catalyst-2940-2950-2955-2970-3550-or-3750-series
Hope it helps
-Randy-
Wondering about if this is also true for higher-level switches ? I am having the same issue on a C 6880 like Paul...
Only port mirroring works on 6880 as well ?
