ASR920 Transmit Discards
awinslade
HI Everyone
I have a fleet of ASR920 and a few (very few) interfaces are reporting transmit discards and I'm suspecting micro bursts as the root cause however the reported avg traffic flow still feels a little low for the risk of micro bursts.
Any hints and tips of finding the exact root cause?
show int below
GigabitEthernet0/0/3 is up, line protocol is up
Hardware is 24xGE-4x10GE-FIXED-S, address is bce7.****.**** (bia bce7.****.****)
Description: *** 1g Link ***
Internet address is 10.1.2.3/31
MTU 9000 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 4/255, rxload 1/255
Keepalive set (10 sec)
Full Duplex, 1000Mbps, link type is force-up, media type is BX10U
output flow-control is unsupported, input flow-control is on
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 18:17:15
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 22744
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 5318000 bits/sec, 1140 packets/sec
5 minute output rate 19341000 bits/sec, 2995 packets/sec
67744644 packets input, 42049513771 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 25106 multicast, 0 pause input
135673743 packets output, 87762724636 bytes, 0 underruns
1218 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Joseph W. Doherty
Well that's one of the things about microbursts, you don't need a high average load level.
Something to try, especially as your interface is gig but with the default 40 packet egress queue limit, bump it up, even by a lot.  Then see if your overall drop rate decreases.
BTW, for TCP, a RWIN is ideally sized to support BDP (bandwidth delay product).  I figure the ideal size for a router interface is half the BDP size.  Likely 40 packets is way too small.
according to the document linked below, you can add a service policy to increase the queue limit. It would look something like this:
policy-map PM_1
class cos1
class class-default
queue-limit percent 100
interface GigabitEthernet0/0/3
service-policy output PM_1
Handling Microburst on Cisco ASR 920 Platforms
https://www.cisco.com/c/dam/en/us/td/docs/routers/asr920/design/Cisco-ASR920-Microburst-whitepaper.pdf
Thanks for the suggestion - I had found something similar after creating the thread for Layer 2 service and assumed that I could do something similar for a layer 3  interface
Andy
From the reference @Georg Pauwen provided, don't overlook the need to also set the queue size (which the policy's % should utilize), possibly larger than whatever is the default.
Further, when setting queue size, it might be best to allocate via bytes.  Packets, of course, are variable sized, so it can be unsure what kind of buffering you'll obtain (although this has been the "traditional" method of queue size allocations).  Possible better than allocating by bytes or packets, would be to allocate by time, as that would/should set a boundary on how much queue latency might be added.
In theory, the queue size, when based on maximum queue delay, should automatically change if you run the interface at a different "speed".  However, I recall (?) there were some issues with that feature not always correctly computing the queue size.  So, again, you might want to use the by bytes size option.
