IOS Upgrade - Min. Flash required
rwawrig
I want to make an IOS upgrade to a Cisco AS5400.
The IOS requirement is 64 Mb Flash, but i have only 32Mb. The IOS that I have now and the one I want to upload are fitting in together in 32 Mb. There is a problem if I upload the IOS ? What is with this minumum flash required?
David Stanford
Remember that an image will decompress into dram when loading. If you load this image which requires 64Mb on a 32Mb flash the device will not boot and will go into rommon.
