06-26-2006 01:39 AM
Is it possible to get traffic utilization per port based on the protocols like TCP, UDP, ICMP with CiscoView Mini-RMON.
Sushil
06-26-2006 05:08 AM
Mini RMON manager is going to give you basic ethernet statistics and history, along with being able to create some rmon alarms.
For the above you would need something that supports RMON-II such as a NAM.
06-26-2006 07:44 PM
Thanks for the reply. But the issue is that the switch we have does not supports the NAM modules. And in the network also there is no device which can support NAM module.
In that case what could be the possible solution.
Sushil
06-26-2006 09:21 PM
You will need an external RMON-compliant probe or sniffer (e.g. a Netscout RMON probe). Alternatively, Netflow data exports may provide you with some of what you want. There are quite a few Netflow collection and reporting options from both commercial and Open Source vendors.
