IOS
ishwar
Level 3
Level 3
I am going to purchase 22 cisco 1841 routers with IOS advanced security.Now I wonder how can I diferentiate the IOS loaded in router is original one or copied one...please advice me.
spremkumar
Level 11
Level 11
If its a new buy out it depends on the mode of purchase either directly thru Cisco approved partners or thru some third party.
In most of the cases if ur going thru geninune Cisco approved partners you will get the original IOS code loaded onto that.
yes ofcourse you will be billed for the same thats for the other feature set which doesnt come by default with the sale.
regds
