IP SLA icmp jitter operation
mcinu4cco
Hello
I would like to track icmp jitter for end host. I verified in documentation that it can be any host as a destination. But i got error on this operation:
 Latest RTT: NoConnection/Busy/Timeout
I verified that there is no firewall between the source and destination and icmp timestamp request works when done manually:
r01#ping
Protocol [ip]:
Target IP address: 10.23.33.6
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface:
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]: Timestamp
Number of timestamps [ 9 ]:
Loose, Strict, Record, Timestamp, Verbose[TV]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 10.23.33.6, timeout is 2 seconds:
Packet has IP options:  Total option bytes= 40, padded length=40
 Timestamp: Type 0.  Overflows: 0 length 40, ptr 5
  >>Current pointer<<
  Time= 01:00:00.000 CET (00000000)
Reply to request 0 (4 ms).  Received packet has no options
Reply to request 1 (4 ms).  Received packet has no options
Reply to request 2 (1 ms).  Received packet has no options
Reply to request 3 (1 ms).  Received packet has no options
Reply to request 4 (1 ms).  Received packet has no options
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
r01#sh ip sla statistics 196
IPSLAs Latest Operation Statistics
IPSLA operation id: 196
Type of operation: icmp-jitter
Latest operation start time: 12:45:21.019 CET Fri Nov 21 2014
Latest operation return code: Timeout
RTT Values:
        Number Of RTT: 0                RTT Min/Avg/Max: 0/0/0
Latency one-way time:
        Number of Latency one-way Samples: 0
        Source to Destination Latency one way Min/Avg/Max: 0/0/0
        Destination to Source Latency one way Min/Avg/Max: 0/0/0
Jitter Time:
        Number of SD Jitter Samples: 0
        Number of DS Jitter Samples: 0
        Source to Destination Jitter Min/Avg/Max: 0/0/0
        Destination to Source Jitter Min/Avg/Max: 0/0/0
Packet Late Arrival: 0
Out Of Sequence: 0
        Source to Destination: 0        Destination to Source 0
        In both Directions: 0
Packet Skipped: 0       Packet Unprocessed: 0
Packet Loss: 0
        Loss Period Length Min/Max: 0/0
Number of successes: 0
Number of failures: 34
ip sla 197
 icmp-jitter 10.23.33.6
 frequency 30
ip sla schedule 197 life forever start-time now
Nov 21 12:57:43: IP SLAs(197) Scheduler: saaSchedulerEventWakeup
Nov 21 12:57:43: IP SLAs(197) Scheduler: Starting an operation
Nov 21 12:57:43: IP SLAs(197) icmpjitter operation: Starting icmpjitter operation
Nov 21 12:57:49: IP SLAs(197) icmpjitter operation: Timeout
Nov 21 12:57:49: IP SLAs(197) Scheduler: Updating result
Nov 21 12:57:49: IP SLAs(197) Scheduler: start wakeup timer, delay = 24796
Jorge Lozano
Try "icmp-echo" instead "icmp-jitter".
The icmp-jitter needs a responder on the other side. You can use icmp-jitter between two routers, one with ip sla operation, and the other one with the ip sla responder.
ip sla 1
 icmp-echo 192.168.17.1 source-ip 192.168.17.2
 timeout 1000
 frequency 30
ip sla schedule 1 life forever start-time now
Hi Jorge
According to Cisco documentation icmp-jitter should work on any IP Device.
I have a similar issue.
1. I can run icmp-jitter successfully to non cisco routers
2. it fails to run to a generic ip device.
Imran
