IP Subnetting
AshokJat
Frequent Visitor
Frequent Visitor
Where we use 192.168.1.0/31 kind of network  ? like /31 network basically....
Can anyone explain... @network,
Ashok
Georg Pauwen
/31 subnet masks are typically used in ISP connections, for the purpose of IPv4 address conservation. On point to point links, you effectively only need two addresses anyway, so using /31 doubles the amount of subnets available.
I think there is even an RFC for /31 masks. The link below has some useful information:
https://packetlife.net/blog/2008/jun/18/using-31-bit-subnets-on-point-point-links/
Georg Pauwen
Aren't /30 nets used at this point? I mean /30 networks contain 4 IP addresses, network address, broadcast address and two IP addresses for hosts. So to connect two devices, you can only use a /30, right?
Oh, I'm sorry, I didn't read the article you sent with your post.
