IPM 4.0.1- Collector configuration problem
cisabucho
Dear All,
LMS 3.0 windows version.There are no devices to select as source devices when trying to configure collectors. I can see the devices imported from DCR under devices on the IPM page. When I press Next without specifying the source, I encounter HTTP status 500 error and on the line next to last I get "com.cisco.nm.cmf.util.AccessLogFilter.doFilter(Unknown Source)".
DHARSH_01
I am having the same problem.. Did you ever get this resolved? If so, what was the resolution?
i had the same problem.
If the RW and RO community is configured a rediscover of the devices should help.
I have deleted the devices under CommonServices Devices and Credentials and started a new discovery. After that i could choose the devices as source.
