IPM and config failed status for ICMP jitter collectors.
andrea.meconi
Level 2
Level 2
Hello at all.
We are using IPM 4.2 to configure the collectors on a 7201. We made an upgrade to software 15.0 to solve bug CSCte85239. Then to make the Admin Tag more readable, we have exported all collectors, edited, and then imported. For all ICMP jitter collectors we have received a config failed status. Config failed when we try to add collector using GUI. We are able to manually configure collector. We have already deleted and added the device from IPM.
Any ideas?
Thanks.
Regards.
Andrea
andrea.meconi
Level 2
Level 2
Router sends an inconsistent value error into get-response message: error should be in the PktDataRequestSize.
This variabile cannot be modified using GUI.
Any ideas?
Regards.
Andrea
I am curious to know if you were able to resolve this issue. I am having exactly the same problem with IPM 4.2 and 3845 routers with IOS 15.0.x.
Hello.
We are evaluating a downgrade to 12.X.
Regards.
Andrea
