IPM and ICMP Jitter
hi,
how to configure IPM for icmp jitters.
can i configure the same for my lan devices and critcal links.
You have to configure source and target device (must have responder functionality enabled). Then you configure type of monitor and time frame (by time frame I mean if it is Real-time, or historical). Just follow the steps.
Then you wait a bit and results should show in IPM tab.
5 Replies 5
Matej G
Hi!
You have to enable responder functionality on devices you are trying to monitor.
how to enable that. pl help.
will it enable on enabling the snmp traps.
conf term
ip sla responder
Which devices are you talking about?
cisco devices only. any other things that need to be configured.
