IPM DB Server Not starting
mnlatif
Level 3
Level 3
Is there a way to re-initialize the IPM Database ?
The IPB DB Server is not starting. We never used IPS before, so there is no useful data in the DB.
Or Is there another way to fix this ?
Naman
You can reinitialize the IPM database using:
ipm dbclean
The ipm command is found under /opt/CSCOipm/bin on Solaris and by launching the IPM Command Prompt on Windows.
Joe Clarke
What version of IPM?
2.6.0 with LMS 2.6.
Naman
ipm dbclean
