IPM error
iqbalkhan
I install common service 2.2 , campus manager 3.5 and IPM V 2.5
i install jre 1_5_0 . now when i open IPM in seed device then error return that java.lang.String message="could not open the file"
so pls can any one expert say which java actually i install for operation that.
Biplob
akemp
Level 5
Level 5
The version of Java you're running is incorrect for the version of software you're attempting to use. You need no earlier version than JRE 1.4.2_10 for it to work.
