Rogue device monitoring solution
cadstillo
Hi all, does anyone know of a good (affordable) network monitorig solution that will notify the presence of rogue devices?
akemp
Level 5
Level 5
It depends on your definition of affordable :) I'm thinking that you're running into a regulatory requirement that needs to be filled :)
Pre-regulatory requirement (I'm sure it will be mentioned or required soon). Free is always nice, but usually wont work as well as something you purchase.
Any reasonable definition of affordable will work with me :)
