IPM issue
v.vasilev
Level 3
Level 3
I've been getting the same error message for a while:
Error in communicating with Group Administration Server.
It may be down or not yet up. Please make sure that the Group Administration Server is up and running, then refresh the page.
I know the IPM Group Administration depends on the IPMOGSServer and CMFOGSServer processes so I tried restarting them. I even tried restarting the Daemon Manager which restarts all processes but the problem still persists. Does any know what could be causing this. IPM is the only application which can not communicate with the Group administration server.
Thank you!
V.Vasilev
And this is the problem. Change this as well as /var/sadm/pkg/CSCOmd/pkginfo so that the FQDN value is correct. Then restart dmgtd.
14 Replies 14
Joe Clarke
Please post the output of the pdshow command.
Hello!
It is in the attached file!
Thank you!
V.Vasilev
All the daemons are running, not not all of them came up at the same time. Reboot the server, then post the pdshow after reproducing the problem. Do not manually start anything.
I did what you said!
Thank you!
V.Vasilev
This looks fine. If the problem is still happening, post the IPMOGSServer.log and IPMOGSClient.log.
Yes, the problem still persists.
/var/adm/CSCOpx/log/IPMOGSServer.log is empty
IPMOGSClient does not exist.
Is it possible that something went wrong after I upgraded both CM (to 5.0.4) and DFM (to 3.0.4)?
V.Vasilev
Post the ipmclient.log and ipmprocess.log.
Here there are!
Thank you!
V.Vasilev
Post the output of the DOS SET command as well as a screenshot of the Computer Name tab from your System Control Panel.
Hello!
This is Solaris 10 OS.
V.Vasilev
Okay, then post the output of the hostname command, and the /opt/CSCOpx/lib/classpath/md.properties file.
root@lms1 # hostname
lms1
CLASSES=pxdm
BASEDIR=/opt
LC_CTYPE=bg_BG.UTF-8
LC_NUMERIC=bg_BG.UTF-8
LC_COLLATE=bg_BG.UTF-8
LC_MESSAGES=C
LC_MONETARY=bg_BG.UTF-8
LC_ALL=C
PATH=/sbin:/usr/sbin:/usr/bin:/usr/sadm/install/bin
OAMBASE=/usr/sadm/sysadm
PRODNAME=CiscoWorks Common Services
VERSION=3.7
PATCHVER=1
ARCH=sparc
CATEGORY=application
DESC=CiscoWorks Process management commands and interfaces
EMAIL=[email protected]
HOTLINE=1-800-553-6387
PKG=CSCOmd
PKGOWNER=NMCihF78oLBcwNg
PRODVERS=unassigned
VENDOR=Cisco Systems, Inc
NAME=CiscoWorks Process Management package
ALIAS=dmgt CSCOmd
BUILD_ID=SOL_CS311_INCR_UPDATE_20071205_1735_protopackage
BUILD_NUMBER=284
PSTAMP=nmch-build-sol28-00620071206131214
PKGINST=CSCOmd
PKGSAV=/var/sadm/pkg/CSCOmd/save
INSTDATE=Mar 05 2009 16:32
DMGT_PORT=42340
DMGT_START=
NMSROOT=/opt/CSCOpx
HOME=/opt/CSCOpx
CWMIBDIR=/opt/CSCOpx/objects/share/mibs
PX_DMGTHOST=127.0.0.1:42340
JAVA_HOME=/opt/CSCOpx/lib/jre
LANG=C
NLSPATH=/opt/CSCOpx/objects/share/nls/C/%N.cat
SQLANY=/opt/CSCOpx/objects/db
ASANY=/opt/CSCOpx/objects/db
SATMP=/var/adm/CSCOpx/files/.SQLAnywhere
ASTMP=/var/adm/CSCOpx/files/.SQLAnywhere
PX_BINDIR=/opt/CSCOpx/bin
PX_DATADIR=/var/adm/CSCOpx/files
PX_DATASTORE=dsn
PX_APPDIR=/opt/CSCOpx/objects
PX_LIBDIR=/opt/CSCOpx/lib
PX_CONFDIR=/opt/CSCOpx/conf
PX_HLPDIR=/opt/CSCOpx/help
PX_DOCDIR=/opt/CSCOpx/htdocs
PX_CGIDIR=/opt/CSCOpx/cgi-bin
PX_LOGDIR=/var/adm/CSCOpx/log
PX_LOGFILE=/var/adm/CSCOpx/log/dmgtd.log
PX_CTRBDIR=/opt/CSCOpx/contrib
PX_FACILITY=local0
PX_TMPDIR=/tmp
I_MODE=NEW
I_CONF_SYSLOG=YES
OSAGENT_PORT=42342
CORE_SECURE_PORT=443
CORE_NONSECURE_PORT=1741
PX_OSA_PORT=42342
PX_JRN_PORT=42343
PX_DMGT_PORT=42340
SVC_ENTRY_WEB=cscoapch
SVC_ENTRY_OSA=cscoosa
SVC_ENTRY_JRN=
SVC_ENTRY_DMGT=cscomd
SVC_ENTRY_SSL=cscoapch_ssl
PX_CLASSDIR=/opt/CSCOpx/www/classpath
PX_SCLASSDIR=/opt/CSCOpx/lib/classpath
PX_CGIURL=/cgi-bin
PX_DOCURL=/
PX_CLASSURL=/CSCOnm/classpath
PX_HOST=lms1
PX_FQDN=lms1.lirex.com
PX_USER=casuser
PX_GROUP=casusers
ODBCINI=/opt/CSCOpx/.odbc.ini
CLASSPATH=/opt/CSCOpx/lib/classpath:/opt/CSCOpx/www/classpath:/opt/CSCOpx/campus/lib/classpath:/opt/CSCOpx/campus/www/classpath
PX_ANI_PORT=42344
MAX_RAM=2048
MAX_SWAP=4096
SYS_NO_OF_CPUS=32
UPDATE=yes
LD_LIBRARY_PATH=/opt/CSCOpx/objects/db/lib:/opt/CSCOpx/lib:/opt/CSCOpx/MDC/lib:/opt/CSCOpx/campus/lib:/opt/CSCOpx/campus/lib:/opt/CSCOpx/campus/lib
TZ=Europe/Sofia
PX_PORT=1741
PX_WEB_PORT=1741
PX_PROTOCOL=http
SYS_RAM=8064
SYS_SWAP=10854744
SYS_CPU=1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
I found one discrepancy in this file:
this server has been installed in different LAN so lirex.com shouldn't be here.
Thank you!
V.Vasilev
Hello!
You were right! It solved my problem. Thank you very much for your help 🙂
V.Vasilev
