12-15-2011 06:11 AM
H Folks,
We've recently started using some 2911's on our network running IOS 15.0(1r)M9. I noticed, much to my frustration that the OIDs with the MIB RFC1213:ipRouteTable1.3.6.1.2.1.4.21 are not supported.
Does anyone know of an alternative MIB for viewing routing table information via SNMP on any of these devices running a similar IOS?
Kind regards
Ciaran
Solved! Go to Solution.
12-16-2011 02:56 AM
Greetings Ciaran,
Can you check if inetCidrRouteTable in IP-FORWARD-MIB provides the data you're looking for? I'm not sure of the specifics for 2900, but I know other platforms have removed some 'obsoleted' objects from older MIBs since 15.0.
Kind Regards,
/Phil
12-16-2011 02:56 AM
Greetings Ciaran,
Kind Regards,
/Phil
12-16-2011 05:54 AM
Hi Phil,
that done the trick thank you very much I was able to get what I wanted from the CidrRouteTable.
Many thanks
Ciaran
