Profinet
sejapirdel
Community Member
Does anyone know where can I find the GSD file for IE3000 ?
Best regards
Jari
phiharri
Level 8
Level 8
Greetings Jari,
The GSD file is contained in the IOS .tar archive. If the software on your IE-3000 has been installed from the .tar bundle you will find it in a subdirectory on flash, example:
ie3000#dir flash:/ies-ipservices-mz.122-55.SE/
Directory of flash:/ies-ipservices-mz.122-55.SE/
  720  -rwx       11506   Mar 1 1993 00:49:01 +00:00  Cisco_IE3000_GSD.zip
If you just have the .bin image on flash, you can download and extract the .tar for your IOS version from Cisco.com.
Hope this helps,
/Phil
phiharri
Level 8
Level 8
Greetings Jari,
Hope this helps,
/Phil
Hi, and thanks for the answer.
I found the file.
Best regards
/Jari
