IPv6 source and destination exported NetFlow-V9(FNF) are both ::.
angelyouyou
As shown in the network topology above.
Regarding NetFlow FNF, I created 2 flow-records (1 each for IPv4 and IPv6), 2 flow-exporters (1 each for IPv4 and IPv6), 2 flow-monitors (1 each for IPv4 and IPv6), and then The g1/0 interface is bound with a total of 4 Flow export configurations for the inbound and outbound direction and IPv4/IPv6. The configurations are as follows (the configuration file and NetFlow packet capture file are also uploaded in the attachment).
But when I ping the IPv6 address (2003::F043:5531:E4AB:8A33) of the PC connected to R1 on the R2 device and try to let R1 export NetFlow, I found that the IPv6 DataSet of the NetFlow packets exported by the R1 device is not as expected. Both the source and destination IP addresses are :: instead of the actual IPv6 address (2003::F043:5531:E4AB:8A33), and the same configuration exists on both GNS3 and real devices.
May I ask what is the problem? Is there a problem with my configuration? How to solve it? Thank you.
flow record fr-ipv4
description Ipv4Flow
match ipv4 source address
match ipv4 destination address
match interface input
match interface output
match flow direction
collect ipv4 protocol
collect transport tcp flags
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow record fr-ipv6
description Ipv6Flow
match ipv6 source address
match ipv6 destination address
collect ipv6 protocol
flow exporter fe-ipv4
destination 10.1.1.254
transport udp 9999
template data timeout 30
flow exporter fe-ipv6
transport udp 9999
flow monitor fm-ipv4
exporter fe-ipv4
cache timeout inactive 10
cache timeout active 1
record fr-ipv4
flow monitor fm-ipv6
exporter fe-ipv6
record fr-ipv6
flow-sampler-map sampler
mode random one-out-of 1000
interface GigabitEthernet1/0
 ip address 10.1.12.1 255.255.255.0
 ip flow monitor fm-ipv4 input
 ip flow monitor fm-ipv4 output
 ip flow monitor fm-ipv6 input
 ip flow monitor fm-ipv6 output
 negotiation auto
 ipv6 address 2012::1/64
 ipv6 enable
 flow-sampler sampler
 ospfv3 1 ipv6 area 0
which IOS images are you running in GNS3, Dynamips or IOSv ?
My GNS3 image(dynamips) is c7200-adventerprisek9-mz.152-4.M11
IOS Version:
Cisco IOS Software, 7200 Software (C7200-ADVENTERPRISEK9-M), Version 15.2(4)M11, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Sun 16-Oct-16 07:53 by prod_rel_team
ROM: ROMMON Emulation Microcode
BOOTLDR: 7200 Software (C7200-ADVENTERPRISEK9-M), Version 15.2(4)M11, RELEASE SOFTWARE (fc2)
R1 uptime is 0 minutes
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19
System image file is "tftp://255.255.255.255/unknown"
Last reload reason: unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19
