12-29-2021 04:18 AM
Hi all,
I am trying to establish an outgoing console over the async port of a IR1101. I am getting a bit stuck, I'm afraid.
I am trying to establish a outgoing serial connections towards another cisco switch over the async interface of the router. The relevant config is:
interface Async0/2/0
no ip address
encapsulation relay-line
line 0/0/0
no exec
transport input all
line 0/2/0
no exec
transport input all
I tried with stopbits, with straight and roll-over cable. No luck.
I simply get this:
XXXXX1#telnet 172.31.244.4 2050 /vrf OOB
Trying 172.31.244.4, 2050 ... Open
User Access Verification
Username: admin
Password:
I can succesfully login, but the console is not giving me anthing.
Is what I am trying to do possible? Indeed, it's for a out of band solution
01-20-2023 08:39 AM
Hi, Anybody has resolved this issue? Thank you
01-20-2023 11:54 PM
the only bit of information I could find is that apparently you need to configure this as well:
IR1101(config)#relay line 0/2/0 0/0/0
Then again, the connection with the switch is made. What port on the switch is the async interface connecting to ?
11-22-2023 08:36 AM
I'm experiencing a similar issue:
We're trying to create a terminal server to be reached over cellular. We have an IR1101 with an attached IRM-1100-4A2T, offering 4 Async ports 0/4/0 through 0/4/3. Going through the documentation, I have created the following configuration to reach a switch's console port through as0/4/0, but it doesn't seem to be working, and I don't really know where to go from here. When I telnet to the loopback on the port, I telnet into the router instead of bringing up the console port connected to the switch. Any direction would be appreciated.
interface Loopback0
description Management interface
ip address 192.168.1.1 255.255.255.255
interface Async0/4/0
no ip address
media-type rs232
line 0/4/0
transport input all
transport output all
speed 115200
relay line 0/4/0 0/0/0
ip host SWITCH 2002 192.168.1.1
IR1101#show line
Tty Line Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
0 0 CTY - - - - - 0 0 0/0 -
* 0/0/0 2 TTY 0/0 - - - - - 0 0 0/0 -
0/0/1 3 TTY 0/0 - - - - - 0 0 0/0 -
0/0/2 4 TTY 0/0 - - - - - 0 0 0/0 -
0/0/3 5 TTY 0/0 - - - - - 0 0 0/0 -
0/0/4 6 TTY 0/0 - - - - - 0 0 0/0 -
0/2/0 50 TTY 9600/9600 - - - - - 0 0 0/0 -
* 0/4/0 98 TTY 115200/115200- - - - - 0 0 0/0 -
0/4/1 99 TTY 9600/9600 - - - - - 0 0 0/0 -
0/4/2 100 TTY 9600/9600 - - - - - 0 0 0/0 -
0/4/3 101 TTY 9600/9600 - - - - - 0 0 0/0 -
* 146 146 VTY - - - - - 1 0 0/0 -
147 147 VTY - - - - - 0 0 0/0 -
148 148 VTY - - - - - 0 0 0/0 -
149 149 VTY - - - - - 0 0 0/0 -
150 150 VTY - - - - - 0 0 0/0 -
151 151 VTY - - - - - 0 0 0/0 -
152 152 VTY - - - - - 0 0 0/0 -
153 153 VTY - - - - - 0 0 0/0 -
154 154 VTY - - - - - 0 0 0/0 -
155 155 VTY - - - - - 0 0 0/0 -
156 156 VTY - - - - - 0 0 0/0 -
157 157 VTY - - - - - 0 0 0/0 -
158 158 VTY - - - - - 0 0 0/0 -
159 159 VTY - - - - - 0 0 0/0 -
160 160 VTY - - - - - 0 0 0/0 -
11-29-2023 12:20 AM
I got it working with the configuration below, but the important part was the cable. I had to build my own. See table 2 on " Connecting and Troubleshooting IoT Devices Using Asynchronous Serial Interfaces White Paper - Cisco ".
line 0/2/0
exec-timeout 15 0
transport preferred none
transport input all
transport output none
line 0/3/3
exec-timeout 15 0
transport input all
no ip address
interface Async0/3/3
no ip address
media-type rs232
telnet <loopback-ip> 20xx (xx = line number)
09-13-2024 05:45 PM
thank you for posting this. I'm currently evaluating something similar but need 16+ async ports.
