IR809 - Upgrade
Niklas.D
So i am trying to upgrade a IR809 - firmware Version 15.7(3)M2 - and going to  ir800-universalk9-bundle.SPA.159-3.M1.bin
I get a timeout
bundle install flash:ir800-universalk9-bundle.SPA.159-3.M1.bin
Installing bundle image: /ir800-universalk9-bundle.SPA.159-3.M1.bin.......................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
The semaphore timeout period has expired.
anyone seen this problem before?
17 Replies 17
Hi Niklas, did you ever find a solution to this? I'm running into this exact issue now as well.
Niklas.D
Hi Yes i made a TAC case out of it.
And you will need to make a on preem installation.
You need to extract the files from "ir800-universalk9-bundle.SPA.159-3.M4.bin"  so you get this
ir800-hv.srp.SPA.3.1.21
ir800-ref-gos.img.1.14.0.6
ir800-universalk9-mz.SPA.159-3.M4
MANIFEST
Upload them to the router.
Then change the boot
conf t
no boot system
boot system flash:/ir800-universalk9-mz.SPA.159-3.M4
boot system flash:/ir800-universalk9-mz.SPA.157-3.M2
After this you need access with console
reboot it and break it accessing rommon-1 ,crtl + c to break at boot up.
then boot with the new file
boot flash:ir800-hv.srp.SPA.3.1.21
(this will not install the new firmware)
This will boot in to the new firmware, when booted in preform a install of the new firmware:
bundle install flash:ir800-universalk9-bundle.SPA.159-3.M4.bin
After the reload check if was a succes with
sh platform nvram
Environ setting
-------------------------- TABLE -------------------
LICENSE_SERIAL_NUMBER=FCW223300HA
LICENSE_PRODUCT_ID=IR809G-LTE-GA-K9
CONFIG_REG=0x102
BOOT=flash:/ir800-universalk9-mz.SPA.159-3.M4,12;flash:/ir800-universalk9-mz.SPA.157-3.M2,12; <<
LICENSE_BOOT_LEVEL=
RET_2_RTS=11:36:56 CET Wed Dec 22 2021
SB_CORE_VER=F01047R15.017cc1eea2019-02-08
SB_ML_VER=MA0061R06.0404022015
Amazing! Thanks Niklas!
This worked for me.
Interestingly, because I initially had a successful install (but then deleted the mz.SPA file like a moron), it seems to be up on the new IOS version after the ROMMON-1> boot flash:.... command.
