08-20-2012 06:52 AM
Is it possible to create an EEM applet that polls multiple counters in a table, add the results per instance and issues a eem syslog message or trap when the sum of the values per instance exceed a defined count ?
What I want to do is have an applet add the values of rttMonLatestJitterOperPacketLossSD, rttMonLatestJitterOperPacketLossSD, and rttMonLatestJitterOperPacketMIA per instance in the rttMonLatestJitterOper Table and then it the sum is > then X issue a EEM trap or syslog message.
It looks to me that this isn't possible unless I create a applet per instance. Is this doable via an applet ?
Jerry
08-21-2012 10:50 AM
With EEM 2.4 and later, you could correlate multiple events in an applet. See
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6555/ps6815/whitepaper_c11-492226.html
or https://supportforums.cisco.com/thread/2049656 for an actual example.
08-22-2012 11:02 AM
Thanks but what I was wondering is whether I can reference SNMP tablular OIDs in an applet without specifying the exact instances. Basically I want to have the SNMP ED poll every instance of a tabular OID variable. Unless I specify the exact OID instance to the ED, I don't believe it's possible to do what I want through the SNMP ED. I wish I am wrong.
