is it possible to create two scripts?
Josiah Inubio
Is it possible this way if I'm making two script? Thanks.
Script 1
For this log:
Apr 24 07:40:01.884 MNL: %LINK-3-UPDOWN: Interface Cellular0/2/0, changed state
to down
ROUTER(config)#event manager applet cell1
ROUTER(config-applet)# event syslog pattern "Interface Cellular0/2/0, changed state to down"
ROUTER(config-applet)# action 1.0 cli command "enable"
ROUTER(config-applet)# action 1.1 cli cmmand "configure term"
ROUTER(config-applet)# action 1.2 cli command "interface Cellular0/2/0"
ROUTER(config-applet)# action 1.3 cli command "no shut"
Script 2
For this log:
Apr 25 11:17:49.881 MNL: %CELLWAN-2-MODEM_DOWN: Modem in HWIC slot 0/2 is DOWN
ROUTER(config)#event manager applet cell2
ROUTER(config-applet)# event syslog pattern "Modem in HWIC slot 0/2 is DOWN"
ROUTER(config-applet)# action 1.1 cli cmmand "reload at 19:00"
62 Replies 62
hi joseph, what is the script to put inside the event manager environment q "
action 3.2  cli command "config t"
action 3.3  cli command "event manager applet reload-at-seven"
action 3.4  cli command "event timer cron cron-entry $q 0 19 * * *$q"
action 3.5  cli command "action 1.0 reload"
action 3.6  cli command "end"
is this it?
All this does is create a variable, q, to stand for the double quote character.  All you need to configure is:
Then you can use $q in your applets to stand for the embedded double quote.
Hi Joseph, I just found an error on using the script and the action doesn't work. It says there's something wrong with the variable "hour". How can I resolve this? Thanks.
Aug 25 08:23:57.362: %CELLWAN-2-MODEM_DOWN: Modem in HWIC slot 0/0 is DOWN
Aug 25 08:23:57.690: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: hour
The output of show clock must not be matching the regexp.  Run "debug event manager action cli" and look at the output to see what "show clock" looks like to EEM.
I have now executed the command, so how do i exactly see the output? thanks
ROUTER#debug event manager action cli
Debug EEM action cli debugging is on
ROUTER#sh clo
14:32:03.655 Wed Aug 28 2013
I meant enable debug, get your policy to execute, then look at the debug output to see what the show clock output looks like to EEM.
This is what looks like.
Aug 29 14:31:07.757 MNL: %CELLWAN-2-MODEM_DOWN: Modem in HWIC slot 0/0 is DOWN
Aug 29 14:31:07.761 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : CTL : cli_open called.
Aug 29 14:31:07.761 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : ROUTER>
Aug 29 14:31:07.761 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : IN  : ROUTER>enable
Aug 29 14:31:08.073 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : No authorization entry found for 172.29.7.17
Aug 29 14:31:08.073 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : ROUTER>
Aug 29 14:31:08.073 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : IN  : ROUTER>show clock
Aug 29 14:31:08.085 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : 14:31:08.077 MNL Thu Aug 29 2013
Aug 29 14:31:08.085 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : ROUTER>
Aug 29 14:31:08.085 MNL: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: hour
Aug 29 14:31:08.085 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : CTL : cli_close called.
Not sure what your applet looks like now, but try this:
action 003 regexp "([0-9]+):[0-9]+:[0-9]+" $_cli_result match hour
ok thanks. i'll inform you if it works.
This is what it looks like. does the script works?
Sep  4 08:19:14.565 MNL: %CELLWAN-2-MODEM_DOWN: Modem in HWIC slot 0/0 is DOWN
Sep  4 08:19:14.565 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : CTL : cli_open called.
Sep  4 08:19:14.569 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : PHILAM-ANT-BR01>
Sep  4 08:19:14.569 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : IN  : PHILAM-ANT-BR01>enable
Sep  4 08:19:14.881 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : No authorization entry found for 172.29.7.17
Sep  4 08:19:14.881 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : PHILAM-ANT-BR01>
Sep  4 08:19:14.881 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : IN  : PHILAM-ANT-BR01>show clock
Sep  4 08:19:14.893 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : 08:19:14.881 MNL Wed Sep 4 2013
Sep  4 08:19:14.893 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : PHILAM-ANT-BR01>
Sep  4 08:19:14.893 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : CTL : cli_close called.
Sep  4 08:19:31.233 MNL: %LINK-5-CHANGED: Interface Cellular0/0/0, changed state to reset
Sep  4 08:19:34.477 MNL: %CELLWAN-2-MODEM_UP: Modem in HWIC slot 0/0 is now UP
hi joseph, there should be an enable password after these bold text indicated. how to put password on it? thanks
Sep  4 16:49:21.764 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : IN  : PHILAM-BLA-BR01>enable
Sep  4 16:49:22.076 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : No authorization entry found for 172.29.7.20
Hi joseph, I think it needed an username before action "enable" and a password after "enable". so how can i put that in the script? thanks
Configure:
event manager session cli username USER
Where USER is a username authorized to run all of the CLI commands in your applet.
is it also possible to configure telnet password and enable password?
No.  They are not used or needed by EEM.
